Configures subVLAN address ranges on each subVLAN to prohibit the entry of IP addresses from hosts outside of the configured range.
vlan_name | Specifies a subVLAN name. |
ipaddress1 | Specifies an IP address. |
ipaddress2 | Specifies another IP address. |
N/A.
There is no error checking to prevent the configuration of overlapping subVLAN address ranges between multiple subVLANs. Doing so can result in unexpected behavior of ARP within the superVLAN and associated subVLANs.
The following example configures the subVLAN vsuper to prohibit the entry of IP addresses from hosts outside of the configured range of IP addresses:
configure vlan vsuper subvlan-address-range 10.1.1.1 - 10.1.1.255
